boot build/false floor
I'm thinking of making a small bootbuild/false floor for my sub to sit in. I have seen a few threads where it looks like people have literally cut wood to the right size, covered it and attached the sub to this. Now my worry with doing this is the sound being awful as the sub isnt mounted in an air sealed box?
Am i right in thinking this or does it not sound that bad?
Any tips/advice would be great!
oh and I've never used fibreglass and would have no idea where to start so i was going to stick with wood.
Edited by moroney
  • Replies 8
  • Views 1.8k
  • what you could do is get a shallow boxed sub and mount the sub on the underside of some 12mm mdf cut the mdf to the right shape and make some stilts out of some wood and you'll be good! i just finis
You'd want your sub in an enclosure which is designed properly really, ie the right volume for your sub/type of music etc
cut the mdf to the right shape and make some stilts out of some wood and you'll be good! i just finished mine to cover my compressor, unfortunately i couldnt fit my sub underneath it so made 3/4 of a false floor and tucked the sub in next to it..
i'll upload a pic later
think this sounds like what I'm going to have to do. Some pictures of what you have would be brilliant.
cheers for the heads up.
There's only one way to learn!
looks good enough to me! anything you'd reccomend over the top of others for attaching the sub to the underside of the mdf?
Cut a hole for the sub to face through then just self tapping screws through the mdf into the enclosure
thanks, ill give this a go!
