Grey breadvan H reg NZ
This thread is for my other car, sold now but i do miss it. I had it for about a year whilst my coupe was off the road.
When I got it it was in a sorry state, solid shell but subject to some bodged mods and and engine running issue. The car had a decent spec, NZ mpi engine, gt clocks, gt front seats, braided hoses, gt gearbox, teardrop alloys, poly arb blocks 90+ k
Some pics from the seller:
not long after it arrived it made itself usefull in the garage by holding the ladders
picked up some needed parts and ran into the first problem
It had been fitted with a ta lowering kit all the shocks were blown and needed replacing but the top nut had been cross threaded and the stub at the top rounded off whilst doing so. in the end we welded a 8mm socket piece to the top so we can hold it in place
Picked up and painted some door handle protectors
some rust treatment
also undersealed the inner arches
painted front struts
  • Views 2.3k
a rare shot of the two together
then this happened
hammer time
it spent quite alot of time like this
I had to rebuild the suspension fully. I replaced:
• shocks springs TA 60/40
• rear bumpstops
• both track arms
• top mounts
• front wheel bearings
• both outer cv boots
• tie rods
• 6n chrome top caps
in solving the idle problem I cleaned the tb and idle screw, replaced the vacuum hoses and bought some 8mm ht leads
Edited by kiran_182
When i got it there were no rear cards and i had a hard time getting some. finally did from the local scrappie.
used some spray fabric dye to get them grey
some pictures from the sale
loving the shot with the ladders :) nice bready man
it was such a cool work vehicle, people responded to seeing an old car out earning its keep. I do miss it
  • 4 years later...
Found this on ebay just now,
"mk2f polo breadvan spares or repairs
The shell was to good to scrap.
Was afh converted but have since sold the engine
Needs engine, engine loom and handbrake cable to put back on road.
No mot
Will come with all interior
Is lightly modified, has lowering shocks and springs all round, wind deflectors (not pictured), arb blocks, aftermarket stereo, clocks with rev counter.
4x100 Volkswagen 14” teardrop alloy wheels. All Center caps are present
Ideal project or would be a good car for spare parts.
Black doorcards and carpet.
The car needs a good clean inside and out.
99p no reserve. Would obviously need trailering away. Would even be good for someone to strip and sell the parts. Grab yourself a bargain.
99p no reserve.
Happy bidding "
The reg was H473 THE from factory
