Is it possible to install seats from a foreign mk2 polo into a british mk2
Hi,
I'm trying to install seats from a foreign mk2 into my mk2 but the latch to adjust the seat is on the wrong side! Is there any way of taking apart the seat to swap the seat bases?
Osgur
  • Replies 8
  • Views 1k
could swap the foriegn seat material and foam onto a uk base
Is that easy to do?
yes very simple
Ok thanks will have a look into that. You dont know of any instructions anywhere do you?
Can you just fit them as they came out of the LHD one? i.e.. passenger becomes the drivers one? Or do you have a height adjustable seat?
Problem has now been solved! Needed to keep old bases and put new foam and cover onto them due to issues with the adjuster mechanism and seatbelts.
Ok cool :)
but I'm still unsure why you needed to. The left hand seat should fit in a left hand of the car irrelevant if its a RHD or LHD one. Its just if you have height adjustable base then it more of a problem! :)
Yea sorry the LHD RHD was irrelevant in the end. It was because vw changed very slightly the make up of the seats just after 82 it seems.....
