Drivers seat fail can it be fixed ?
Hi and happy new year , ok my front seat in my mk2f polo is not working when you lift the side leaver so you can get in the back the seat it does lift and tilt forward . Can it be fixed or a replacement part ?
  • Replies 8
  • Views 883
They are cable operated so must likely a cable has snapped or come un hooked if its snapped u will need a replacement. I'm unsure if vw sell them
Ok thank you , is it best i remove the seat and have a look ?
the cables were avail a while back , i replaced mine , they're only about a fiver or so
otherwise slash a working seat at a scrapy and have the cable out
I will try Febi maybe ?
Thank you just found one on ebay by febi for 12pound so heritage works out a lot cheaper thank you ?
vw is only £8 so ebay is a bit rude
Very rude lol.
