6n door card material change guide?
Is there a step by step guide on here with pictures on how to take door cards off and retrim them. I've seen a few posts of people doing it on their cars but not really guides. I'm thinking about doing this but don't wanna ruin my door cards.
Edited by stormtrooper
  • Views 1.6k
I've not seen a guide on here but i have had a go at this myself.
It's a bit tricky so you'll need a bit of patience.
1. Remove your door cards:
Pop the grab handle cover off using a small flat head and you'll find 2 Phillips screws behind it, remove these.
Pop the mirror cover off towards the top right of the door card (It's just clipped on)
Unscrew the top of the lock pin.
The rest of the door card is just held on by clips now ( on the drivers side you'll need to pop out the lecci mirror switch if you have them)
Start to pop the door card off from the bottom and remove it from the car.
2. Remove the grab handle:
Flip the door card over and you'll find 7 Philips head screws holding the grab handle to it.
Remove all the screws and it'll come away.
3. Remove the existing materiel:
It's just glued onto the door card so needs pulling off, you'll need to be careful along the edges not to tear the rubber like edge that covers the material.
4: Re trim:
This is the Blue Peter part, cutting and sticking!
Get hold of some material that tickles your fancy and some good interior adhesive, I personally used Trim Fix for all my interior re trim jobs,
It's now a case of gluing your martial over the bare part of the door card, making sure you use plenty of adhesive and get it sitting flush in all the corners with no creases, the hardest part I found here was getting a nice clean edge along the top and bottom, If you've managed to take the old material off without damaging the top/bottom edges then you should be able to tuck your new material underneath.
There's a couple of pics on my build thread of when i did mine if you'd like to get an idea of how they look:
http://www.clubpolo.co.uk/forum/index.php?showtopic=325711&page=2
Hope this helps!
Edited by BoWzER
Wow! More detailed reply than I expected. Yeah it was seeing yours that made me wanna try mine. If I do give it a try, I shall post pics. Thanks again.
