6N2 GTI 5dr Breaking - Derbyshire
Currently breaking a silver 6n2 gti 5dr.Car has done approx 94k miles, running gear in good working order as far as I can tell.
Items Left
Loom/ecu
engine cover
alternator
Air con rad
aircon pump
driveshafts
front calipers
standard shocks&springs
gti arb
clocks
air con controls
engine cover
centre console
gearknob & gailter (slightly worn)
steering wheel/airbag
wiper stalks
starter motor
radiator fan
slam panel
headlight washer jets/pump/pipework/bottle
headlight switch inc front fog option
abs pump
header tank
exhaust downpipe & cat
exhaust system
xenon level sensor
centre dash radio section
engine undertray
fan control relays
front grille
rear lights
fuelpump
clocks
clock surrounds
handbrake
dash centre cubby box
towing eye
Located near Matlock in Derbyshire
Matt 07944 884008
Edited by pettsy
  • Replies 61
  • Views 2.7k
hi, i need the drivers side window switch if you'de be so kind
Do you have front left fog light casing (and bulb if pos) if so how much :)
Need a drivers side window reg and motor chap. Can you post? Cheers.
Ash
I think the drivers switch may be faulty so don't want to risk selling. Foglights have been provisionally sold pending collection this week. Drivers side window reg and motor is available, £40 delivered.
I only need the plastic top case :)
How much for the seats please?
Hi I'm after the drivers regulator an mechanism an the gear linkage cables
Please
Rear bumper/foglights/cd changer/cupholder SOLD
Seats- drivers has a bit of bolster wear and cloth damage iirc,so open to offers, Will get them out this weekend and post a picture up.
Window reg/motor is still available. Selector cables will be available once gearbox is removed from car (I do have some allready removed from a 1.0 if they're any use?)
hi mate, what nick is the gearbox in?
how much for the gearbox if you will break it off the engine?
The lad I bought the car off said the Gearbox was a re-con one he had fitted. It feels very light to me,but I'm used to a cable clutch/rod selector. Its still in the car so can be tested etc. I'm looking for around £150.
gti splitter how much?
Not sure what its worth as it has 2 cracks when I loaded the car onto my trailer.
what condition r the alloys in and how much u after for them if u still gt them? pm me
I'm keeping the alloys for now.
car has now been stripped, all remaining parts are in the first post!
Let me knw if u decide to sell drop me a pm cheers
Assuming the seatbelts would fit a 3dr?
if so how much?
Hi, is the splitter not available because sold or just damaged?
I'd still be interested in it even if it's snapped in two!
Cheers,
Beinn.
Cheers,
Beinn.
Was because I cracked it in two places loading the car onto my trailer. Its still attached together as such.
Cheers,
Beinn.
Ok mate, could you pm me some pics?
Thanks.
yes,will sort some pics out for you.
Could do with engine conversion out of the way asap, so open to sensible offers?
How much for just the engine? Need a replacement for my gti
£200
