Polo problem
Hi guys just wondering I used my window switch earlier and then when I did my dashboard and also my head unit All went off then when I let go it all came back on also my and light came on everytime I used the switch help need this fixed ASAP
  • Views 618
  • polo-trigger
    polo-trigger
    Replace the wire leading to the switch, or check the wire running to the switch, find any worn through parts (showing just the bare metal wire) and repair it by wrapping electrical tape around it / ma
Replace the wire leading to the switch, or check the wire running to the switch, find any worn through parts (showing just the bare metal wire) and repair it by wrapping electrical tape around it / make sure the wires not rubbing against any piece of metal or connection that it should'nt be and hopefully the problem will be solved ;)
Sweet thank you will do that when I'm off next much appreciated
