Leaking 2002 Polo 9N
Right now I know this is a common problem etc, and I had the problem back in the summer when it rained a few times, but it wasn't much of a problem, I investigated, and it turned out that the nearside rear light didn't have the nut on the back of the light securing it to the body, so it was just clipped in and loose, which made the boot wet, and the rear seats. I put a wing nut on and tightened it to the body work and that seemed all okay.
I don't know if it was coincedence or not, but just before christmas, my polo went for MOT and on the sheet it says rear light bulb, and since my MOT I've noticed the wet problem... the rear seats were soaked, as is the boot. I've kept the seats out the car, and the back has dried out. I removed the suspect rear light, checked the seal, tightened it onto the body again, but I'm not convinced it's working, the windscreen still massively condensates and mists up over night.
Here's a yahoo answer thing of exactly my problem, I had to remove about 4 inches of water from above the rear bumper on that little hole below the rear light.
I seem to be getting water that is coming through the rear left side of my vw polo, the water seems to collect somewhere in the rear bumper area? and if i put my hand down the inside of the boot down the hole on the rear left side, i can feel there is alot of water collecting, its like there is a massive puddle there. The water has also flowed out from there in to the rear footwell and into the rear left side of the seat. How can i stop this from occuring and how can i open up the area to remove water and further investigate the leak?
Is there anything I can do to sort this? As I'm dreading when it starts getting cold and my windscreen freezes from the inside...
  • Views 6.5k
Thought I'd update with pictures, as they help.
I noticed the holes on the body were a bit bent..
So I hit them with a big hammer which was fun, flattened them out
Here's some random image
Below, this is where the water fills up and makes a fish tank out of the void, might buy some gold fish.... I got a piece of tube, syphoned the water out (drinking a bit of the horrible black smelly water)
A couple of the light..
You can see where it's wet
After hitting the car with the big hammer, the light now actually sits close to the body, which is making me think it might be better now? Compared to the other side, this side was always a good 4/5mm away from the body
