6N Tail Light/Boot Water Leak
Hi All...
Back in Summer when we had a few days of rain I found I had water in my boot area, not a lot and not enough to make any kind of pool but it was all over the spare tyre like condensation and soaked some of the carpet. Anyway I plugged some leaks with standard silicone including the boot air vent which was drenched with water... the grommets/plugs at the bottom of the boot where the spare wheel seats and my left hand side rear light cluster. They lasted up until recently and now the problem has risen again... Can I get something stronger to protect from water or is there somewhere that might be able to sell me new sills to go around the lights? Or at least something I can use a substiute? Do you reckon it's worth popping the rear bumper off and sealing up the air vent from the outside as well as the inside? Will obviously need something strong that I can get my hands on!
Any help would be much appreciated as I'd rather try to fix this altogether when I have the chance rather than just siliconing it again and hoping it will last out for a few months. (From experience it doesn't last at all especially with all this shitty weather we've been having in the UK.
  • Views 5.6k
Are you talking about the boot vent on the lower section of the quater panel with the 2 flaps?
Been having the same issue with my boot leaking up and making a small pool of water on the passenger side. Got my mate to run the hose on the back of the car while I was inside and saw all the water gushing out of the boot vent. Not from the flaps but where the plastic sits into the metal. Going to silicone it up on the weekend and hope it stops. Cant fit my air ride on until i get this sorted as i dont want it to damage the air manifold.
Vish
Vish
Yep, water coming from there as well as the rest. I put a good amount of silicone over it and it's held since Autumn last year... I don't think water is coming from it this time but going to check today.
^ No water from there, I did coat it in Silicone though... I put some more over this afternoon just to reinforce it! I hope it solves your problem!
Cheers pal, hopefully :-(
Let me know how it goes!
Ok, still leaking... Took some photos to see if anyone can help out? I'm going to get someone to pour water over the car and sit in it soon... the third photo it looks as if the water is coming through the tiny gap where the metal folds over? Also my '4 hour to dry' silicone sealent is still wet after 24 hours... :angry:
Edited by therewillbeblood
