Interior 6N2 Seats help?
Hi there, this may seem like a silly question but I'm after a whole new set of seats for my 6n2 but I'm not 100% sure what fits into my car... I know a guy who's selling mk3 vr6 leathers but before i go any further I'd be interested to know what you guys have in your 6n2's ? 😊 thanks for the comments in advance.
  • Views 821
I have got vr6 front seats in but rears need ajustment
I have Late MK3 Golf Recaros. You will need to swap metal backs from your polo on to the golf foam and upholstery, as Golf rear seat are 40mm wider overall than those on a polo. rear bases will need removing of the brackets that hold them to the chassis on a golf. To achieve this you will need to ether pry metal apart on a bracket or file the flares on a wire sub base to slide them off (make them same width as rest of the wire) ((PS later would be my personal choice)). DO NOT USE HACK SAW TO CUT FLARES OFF as your bases will keep poping out of the eyelets in your polo. It will also benefit if you will ever decide to flog them again and someone will want to use them on a MK3 Golf again.
Hope this helps.
PS. I have Seat Ibiza Cupra Half leather for sale on here. Direct fit just need wires sub base to be replaced with the ones from polo. basically anything out of a MK3 Golf, Pre 2002 Ibiza's and obviously polos, will fit. Golf seat require more time to fit. Just to compare, for both front and rears, Ibiza/Polo 25 Minutes, Golf 50 Minutes to 1 Hour.
EV
