afh and avy parts and aee engine
I have a fair few spare parts lying around so time for a clear out,
Basically whatevers in the pictures
- afh block with internals but sump is damaged, exhaust manifold, rocker, cams, head(head has a damaged valve seat and couple bent inlet valves but i think the exhaust valves are ok.)
-Avy flywheel, engine cover, head with both manifolds, rocker with cams, ecu, engine loom, throttle position sensor.
-Aee engine 67k-£30
I'm going to say £20 an item as i want them out the way.
Collection from dudley west midlands or can post smaller items
Edited by nu99et18
  • Replies 16
  • Views 1.2k
Hello, will that avy exhaust manifold fit my ahw engine? If so how much would it be posted to ng11? Brad
Hi,
No idea tbh mate, its prov sold atm anyway
Also prov sold
-afh and avy heads
-aee engine
how much for the 8v cam cover posted and do you have the platic guide the plug leads fit in with the metal clips that hold it to the head?
zero 7789 18 48 58
Both prov sold mate sorry
Do you have the bottom crankshaft pulley for the alternator belt?
Edited by G2racer
For which engine?
AEE still there? Can pay now and collect this week.
Sold sorry mate.
To update
Aee sold
Afh head with cams etc sold
Avy head complete sold
Alternator bracket sold
Only couple things left
Avy
engine cover
flywheel
ecu key and transponder unit
throttle pedal sensor
engine
possibly the loom aswell
Afh block with internals(damaged sump)
For which engine?
AFH
Hi have you got the sump of the avy?
No sorry pal
Hello mate have u got the cambelt side engine mount the one that bolts to the head/block ??
I might have mate,is this for the avy engine?
Still got couple parts
Afh block with internals but damaged sump £20 collected
Few avy parts ecu, engine loom etc
Any pics of the afh block? (bores etc)
Where are you located?
I can get some, located in dudley west midlands.
