wobble bolts and spigot rings
Just got some revos and need to know what size spigot rings for them they are mini fitment. Also wobble bolts where can I get them? To fit a mk3 btw
  • Replies 8
  • Views 1.8k
Both can be found on ebay. You'll need to measure the bore size on the revos and get spigot ring to convert down to 57.1mm and M12x1.5 wobble bolts
Hope this helps
What length bolts do you think? What length are standard bolts?
Measured mine at 23mm
Remember minis use wheel nuts, and revos have sleeved not tapered holes, so ideally you need to use the proper revolution sleeved nuts.
Not sure how you get around the given the fact that polos use wheel bolts?
As had been said. Revolution wheels (well the Mini ones) used sleeved wheel nuts as they are studs on a Mini (see pic below)
As they also have no taper for sitting the wheels bolts in I don't think there are any wobble bolts that would fit these wheels.
I suppose if the wheel allows you could machine in a taper and then use wobble bolts but it seems a lot of work...
Stud conversion either properly done or adaptors are probably the easiest way to go.
If you were to do that you might not need spigot rings, as although they're an awkward design the wheel can't move at all with them fitted.
Edited by derskine
On the back of the wheels it lists both 4x108 and 4x101.6 really weird
yeah that's because they use different bolts I think, the mini ones use a small diameter nut internally and the ford ones use a larger internal nut, which obviously changes the pcd
