Mystery tube
Hi,
Can anyone tell me what the tubing is that is hanging down underneath my car around the back right tire. It is soft and flexible like one of the tubing for the washer bottles and has a black valve thing on the end.? What is it and how do i fix it!?
Mk2 polo c by the way
  • Views 1.3k
  • That's the one! Although I'm not entirely sure why it's so long and why it's got the rubber boot thingy on the end? I think I'd just cut it of tbh. Nobody should be overflowing or dripping fuel in
Either a fuel tank breather or, if you have a factory sunroof, a drain for that.
No sunroof so must be fuel tank breather. Anything I need to do with it?
It connects to the top of the filler neck, I just stuffed mine between the filler neck and body, it's a breather I think.
Max
Its actually the overflow drain for the filler boot, if you overflow fuel into the boot around the filler neck, it flows down this tube and on your feet/floor!
That's the one!
I think I'd just cut it of tbh. Nobody should be overflowing or dripping fuel into the filler neck boot, that shits too expensive to waste :lol:
I Think the rubber flared boot is to prevent road grime from blocking the pipe up. You could shorten the pipe and push the boot on afterwards to keep it looking tidy.
Good idea cheers!
