Roof headlining
Hi there, don't suppose anyone on here has removed the roof headlining ? I'm thinking of having a change but not sure if it's an easy or hard change.
  • Views 890
It's easy 10 minute job.
Remove: interior light, sunvisors, grab handles, A,B,C pillars, pull each of the door seals down at the top and boot seal
Basically remove all clips/items in the roof lining. It's not glued in or anything
Remove it by pulling it out through boot
10/10
just to add be careful no to break the interiour light wire when removing, mine got caught and i didnt notice :angry:
Thank you for the help, is it just as easy to put back on :)
It is
Does this hold true with the mk2f? Id like to give swapping the fabric a go but it looks like its tensioned
