Hey guys, could someone please tell me how I go about removing the following for spraying:
Passenger, driver, windscreen vents
Centre console surround
Dashboard dials hood lip
+ anything else you think would be nice to spray
Pictures would be appreciated
  • Views 1.4k
You'll need a T15 Torx bit (could be T20). Remove the stereo and there will be some screws dotted around behind it at the sides, drivers side vent with light switch has a screw underneath I think, passenger side may just be a pull out carefully job as with the top dash strip. The clock cover has one screw in the top middle I think.
These are all off the top of my head so could be wrong, but shouldn't be far off, its pretty straightforward. They should just pull out after unscrewing for the most part, just make sure to unplug any plugs behind them :)
Edited by R10tz0r
