6N1 Horn replacement suggestions?
Hi,
I am looking to replace my horn in my 6n1 mk4 polo 97 plate. I currently have a horn in my car that barley works and my MOT is in march! :/
I am looking for a horn that can fit to the original wiring loom but doesnt sound like I stole it from a scooter.
I appreciate any and all help.
Cheers,
Rhys
  • Views 918
Any idea of the fuse rating and/or cable size, i would suggest an airhorn (most come with relays and so on anyway if you wanted to fit it to the stock loom)
Hi,
Unfortunately I am a complete novice when it comes to car electronics, I only know it's the stock loom :/ sorry.
Thanks,
Rhys
Well you can either go get a standard/uprated normal horn or go for a pair of air horns.
Most standard and uprated horns will be fine and should be almost plug and play, Air horns may need to use a relay, but all that really involves i running abit of cable from the battery to supply the horns.
heres some from halfrauds http://www.halfords.com/webapp/wcs/stores/servlet/categorydisplay_storeId_10001_catalogId_10151_categoryId_165704_langId_-1
I myself have the twin Ring airhorns installed on my polo, the only advantage of paying the extra £5 from halfrauds compared to an unbranded set si you egta respectable name behind the product (ring) and a much better warranty.
Get yourself down the scrappy and look for big execative type cars, go nab the horn(s) of one of them (testing with a small 12v battery). Fitting is plug'n'play, so nice and easy. Now your polo will sound like a big-boy car - like mine!
Good idea :)
I personally enjoy twin air horns because of the element of surprise.
