Need help!
Has anyone in the Diss, Norfolk area got a vagcom fault code reader who can give my Passat a once over?
I have an issue with the accelerator at the moment when I lift of the pedal and I'm coasting the car suddenly accelerates on its own in little spurts. I'm thinking its the throttle position sensor or maybe the MAF sensor?
Its a 2003 Passat PD130, hopefully if I can clear any faults it should fix the problem.
  • Replies 10
  • Views 831
nobody has one then?
.... ok, so does anyone know somewhere I can go to have this done at a reasonable price?
Any help at all would be appreciated.
Fuck me over 3 weeks without a single reply?
Am I being ignored on purpose or does litterally nobody know anything about VCDS/vagcom??
I've got the full VCDS but I'm a bit far from you in Milton Keynes! (100 miles)
Thanks for the reply! But shit yeah that is a bit far to go really, hopefully someone a bit closer will be able to help, if not its off to get shafted by my local garage :lol:
I will definately be ordering one of those. Nice one! :)
