Hello, I've got a 6n2 and i seem to have the same fault on both windows, when i use the switch to put the drivers side window down it will go do and stop but when i try to put it up it will go up dlightly then just go down so it bellow the seal then stay there and not move then il try put it up and it'll come up for abit and il have to push it the rest of the way so its closed.
And on the drivers side it'll go down to where i want it then when i hold the switch so i goes up it goes up slowly then kind of just slows down and seems like its stuck, then il have to push it the rest of the way up whilst holding the switch.
If anyone has any ideas or know what it could be ?
Ben
  • Views 1.5k
That's how they came from the factory! Joking it's a common fault.
Similar topic here where they found a solution
http://www.clubpolo.co.uk/forum/index.php?showtopic=231825
Edited by vdoubleu
still not to sure what needs to be done with these windows though
