Bucket seat mounting
i'm going to be buying some bucket seats in the near future and i'm wondering what the best mounting option would be, the seats I'm buying can come with universal seat rails.
Main options i think are:
- Corrado subframes and mount to them (would need modifying too for a mk1)
- Universal rails to a custom frame on the seats
- A proper bucket seat subframe with the rails attached
any better ideas?
Edited by JordonVW
  • Replies 10
  • Views 1k
get proper frames or make some. mounting them on vw bases are shit because theyl be too high as the vw frame is actually part of the seat
Mine are mounted to original seat runners and they sit just right eric but i suppose it depends if the seats are bottom or side mount.
mine are bottom, although i like them nice and low. had my recaros mounted on vw frames and it was a bit shit, all personal taste i spose :)
they will be bottom mounted, you running custom frames then eric?
yeah i am. i used these, and then modified them to fit my seats aswell as sit lower down.
1470822_10151989570950210_2123674702_n.j
universal rails on a custom frame with polo rail mounts welded on?
thats pretty much what they are, they dont slide in the polo rails though, the catch in the polo floor goes through a hole at the front, and you tighten them at the rear just to clamp them in place, then the seat slides on them instead
sounds good, sit low enough? now i'll just need someone to fab me some up
didnt at first, the mounts that go in the runners bolt through the legs, so you just drill the hole to bolt them through in a different place to adjust the height. mine are fairly low now. i could cut and flip the rear mount and adjust the front one but it dont sit too bad atm
I had cobras with polo runners. Had to shortern the rear legs and my head still touched the ceiling. Still got those Rado bases (a mate has) if your ever bothered Jords
