vw polo wet passenger footweell
Hi
I'm new here I've been reading as many posts about leaks in vw polo as I can find.
Its a 1996 p reg polo, with 2 doors.
Anyway, I can't see any sign of a fault / perishing with the door seal, and I've pulled the carpet back and felt behind the glove box but doesn't seem to be any sign of wetness.
My dad said the bodywork is pretty solid and no sign of rust underneath.(or anywhere really, except for one tiny spot on the opposite door)
I lifted up the bonnet and removed any mulch I could see. I also made sure the hole at the bottom of the doors were unblocked.
Does anyone know If I have a pollen filter? Do I have to remove the scuttle panel? Apparently its easy to cock up and break the clips?
Does anyone have any other advice?
It not a massive leak atm, but may get worse if ignored. The frozen inside windscreens are pretty annoying too!
  • Views 1.2k
My 6n 1.0 had a pollen filter. Both times I've had a leak it was leaves in the rain tray.
OK. Cool. Thanks.
Any chance you can remember how / where to access it, without breaking anything?
I didn't do it so can't help sorry
OK no worries thanks anyway!
