Water in the footwell. Coupe GT 1991
Woke up this week to find the drivers side footwell full of water. Took the seats and front carpet out. Stored the carpet and under felt in the shed to dry. Dried the car inside in the garage for a few days. Today tried to work out where the water was coming in. Ran a watering can of water into the battery tray. No water in the car. Poured water down the sun roof drain. No water. Poured water around the door frame. Bingo. Door seal leaking. This one is a scrap yard replacement of an original.
A new seal is an obvious answer but I'm on a budget so. Any suggestions on a possible sealant answer????
Edited by c.w.pritchard
  • Views 731
Anyone used Sikaflex?
No but I have used tiger seal..
where are you hoping to put the stikaflex sealer ...post back with details where its getting past the seal
are you double sure its not coming under the door card
As mine was and still is coming from under door card..
Running in the corner where the seal runs upwards from the footwell. Ran water around the door line across the top. When I opened the door I could see the water running down the inside of the sill into the footwell. I intend running sealant into the seal and then pushing it firmly back on to the door surround. Hope the sealant will expand and contract with temperature change.
yeah tiger seal would do that job...
