Letting water in
Hi everybody, I have a 1990 breadvan (mk2f) which has been letting water into the passenger side footwell.
I have not had a good investigation yet to see what the problem is due to getting home from work when it is dark and the fact that it is always pi$$ing it down up here.
I should manage to get the car into the garage soon though to have a look so I thought I would ask on here what are the common problem areas that could be causing this? I have had a look at the door seals and they appear to be ok but who knows? Just thought I would tap into the wealth of knowledge on here to see if this is a common problem and maybe it could help me locate the leak much quicker.
Many thanks in advance
Paul
Edited by Santaclaus
  • Replies 8
  • Views 2.1k
have a look about, there are a few threads on this problem. people will be reluctant to repeat themselves here too
Hi there I have a polo 9n 2002 and have water coming into the boot it appears that's it is coming in from the two vents that are under the carpet floor on the panel of the rear bumper and this is filling the spare wheel well up. I don't really want to drill holes and take bungs out I want to stop it coming in through these vents have you got any suggestions on how to stop this! Many thanks
Have you run a hose over this and looked at it? My 6N does this but the water just comes out and straight down through a drain hole and onto the concrete.
Paul
Check the door membrane behind the door card, it's a plastic sheet that stops water coming in front the window, if its ripped or loose it will let water in.
Also check for rot around the windscreen seal as even a tiny hole here can soak the footwells.
Check the bulkhead around the fusebox for holes too.
Yeah but surely it's not designed to leak in the first place as the vents are 4 air circulation and yes I have had someone run a hose while I was in the boot and the water was dripping on the concrete but was also getting in through the vents but I don't know whether the window rubber seal that goes over the lip of the boot and seals the tailgate all the way around would stop it if I bought a new one as it does look abit perished I have also checked the tail lights and it's not coming in through them just the vents was just wondering if anyone else had this problem and if so how did they fix it!
Edited by Brembo25
I bunged aload of silicone around mine as there was a lot of water coming out originally, water still comes out but theres a drain below it for a reason. I'd run water over the boot then see where that goes. Good luck.
Yeah have done the water and it is coming through the vents and in to the wheel well so will change the seal and if it still carrys on 2 leak will block the vents up but thanks
