02 plate polo revs
The polo revs and then drops
It keeps doing that for about 5
But doesn't stall
1.2 L manual
Dose anyone know what's up with it
Thanks people
  • Views 617
Clean the throttle body and check the rubber hoses connected to it and the inlet manifold for any splits/cracks
as above you may have an air leak, spray a tiny bit of of brake cleaner or engine starter around the inlet manifold and if your revs go up then you most likely have an air leak
