Door card foil mk2f coupe gt
I've had water issues on my 1991 coupe gt. Striped the carpets and seats out. Took the drivers door card away and found the liner foil in a real mess. Previous owners ripped apart . Would like to replace with original if any one has a drivers side in good condition. If not. What would be a suitable replacement material?
  • Views 693
B&Q is your best bet. Plastic sheeting, use your doorcard as a template, double sided tape, winner.
yeah everyone just uses some plastic sheet cut to size
Am in the middle of doing this , I have lined the back of the door card for extra protection..
don't order it from VW the part number on ETKA is wrong - you get a foam liner instead of a plastic one!
Fish pond liner is good!
OK
