1984 Comet Blue Mk2 Polo Coupe
A Reg 1984
will come with 12 Months MOT & 6 Month Tax
75k 'GF' 1272cc Engine - partially rebuilt see below
4 Speed Gearbox
Top-fill radiator - new
Aftermarket sunroof
VWII Brakes with 239mm discs
Powerflex Anti-roll bar bushes
G40 Steering Damper
G40 Steering Arms
G40 Track Control Arms
Straight through mild steel system
Black carpet in good condition
Black headliner uncut - supplied but not fitted
GT Front seats in Grey
60mm lowered front springs and uprated shocks, new top mounts and bump stops
40mm rear lowered springs
New rear brake flexi hoses
Its had a respray at some point in its life, the paint is in really good condition!
The following has been replaced on the engine
Crankshaft Seal (Gearbox End) 068103171F
Crankshaft Gasket (Gearbox End) 026103181B
Crankshaft Gasket (Oil Pump End) 052115189B
Crankshaft Seal (Oil Pump End) 068103085E
Oil Pump Drain Pipe Gasket 052115257A
Water Pump Gasket 030121043B or 030121043A
Sump Gasket 032103609B
Sump Washer N0138492
Flywheel Bolts N90206103 x6
Cambelt 052109119
Oil Filter 056115561G
Ignition leads
Spark Plugs
Rebuilt Seat Ibiza Mk1 Distributer and electronic ignition conversion
NOS Alternator
Engine block has been painted blue,
Has a few shell modifications
Crossmember was previously removed for the turbo conversion, a new crossmember has been welded in
Holes made in front valance for intercooler airflow
Couple of minor alterations to front panel to allow radiator to clear turbo that was fitted
Upper bulkhead hole for Mk3 Wiring loom (ecu in rain tray to engine bay)
Battery tray, part of the inner wing and jacking point were all rotten, this has all been cut out and welded up.
Studs welded to rear chassis leg to allow mounting of Mk3 Fuel pump assembely
Mounted gauges in dash.
All rot cut out of the fuel filler area, repaired, epoxy-mastic'd, seam sealed, overpainted and undersealed.
Black Coupe S arches all round, and lower sill trims
Asking price £1,500
Build thread -
1984 Comet Blue Polo Coupe S G40 Turbo
Should be available from the next two weeks onwards.
Pictures will be uploaded later this evening
Car is located in Manchester.
Please email yousafn at gmail.com
Edited by grungeisdead
  • Views 514
Just realised that I don't have any wheels to go with this, so I will take £1,150 (with tax and MOT, or 1,000 without)
If I get some wheels for it, I will add the cost price to the cars sale price
