How do I get the aerial down on my Mk2f?
Hi guys, probably a stupid question but haven't had this car too long and it is my first! But was wondering how i got the aerial flush in it's unit? I've heard i have to use the small, flat key i got with the car or something?
All help will be appreciated!
Cheers, Dan.
  • Views 733
just push it down , if it hasnt been used latley you might need to wd40 it and work it up and down a bit
Do you only need the key to pop it out then? Must be wedged, been like it for a year since i've had it! Only been driving it for about 6 months though :) Cheers mate!
They're retained by a mechanism which requires you to pop it out with a key, though truthfully there's a load of things you can use instead.
It's so people don't bend it when you park up somewhere.
So should it literally push down? Or does they mechanism have something i need to press to allow it to go down?
