YELP :O one of two things... break pads (cheap) gearbox (not so cheap
Hey iv got a 6n2 polo gti, she is sitting at 116k miles and I have full service history and it was last phone at 103k before I got her...
Anyway, she has a high picthed screech coming from what seems the left hand side while driving...
It happens when I'm in gear crusing along.. but when I give her some beans she stops... until I start to cruse again...
When I put the clucth in she also shuts up..
I think she may be in need of a new / refurbed gearbox..
Anyhelp is great
  • Replies 9
  • Views 669
Doesnt sound like the brakes if it goes if you put the clutch in whilst moving.
Sounds to me like either something is catching somewhere (when you accelerate the front lifts up)
Most likely its a belt or even a bearing on alt etc, they often squeel at a certain rev range.
Never heard of a gearbox squeel.
Is the squeel consistant, the same every time, not changing pitch?
Recording would be helpful.
Maybe try revving at idle, go through the range slowly and lift the bonnet up. Also check the belts for wear?
Iv taken a recording on video... whats the best way to share em there is three? Just youtube or anything better...
I think it could be a belt or something...
i upload to photobucket and link it
Ill upload them when I get home then :)
That almost sounds like what my gearbox is like but a lot worse, does it do it in neutral? Just like a grinding noise ( crrrrrrrrrr ) and goes when you put clutch in? If so its the input shaft bearing, but isnt much to worry about.
However listening to the engine bay id say you definately have a bad bearing on your alternator. Get a long screwdriver and put the metal end on the alternator when the engine is running (be careful) and the handle end up to your ear, ontop of your hand if its easier. It should sound like a gentle hum, if its screetching etc then theres your problem.
Other than that, just get a spanner and whip the belt off, theres an automatic tensioner, looks like this,
On the right hand side of the image theres a square bit, thats where you put your spanner on and push down (if i remember right).
Very easy to do, i think if you release it far enough it will hold itself with a pin, cant remember lol
Then just move the belt out of the way, and spin the alternator bearing.
Make a not of how it came off first in case you forget.
Hope it helps.
As long as I know its nothing major imma happy lol... my house mate is a mot tester and is going to service it and do its mot so ill get him to do that aswell :)
Amd when I'm in neutral its silent... only when I'm in gears
Turns out she is doing it in neutral
