Painting plastic trim prep info please help advice needed
Want to paint rear plastic trim above licence plate on my polo mk2f. I will be using rattle cans and I know I need plastic primer , top coat , lacquer. But am unsure on what grade paper I need before I lay down the primer ?
  • Replies 20
  • Views 1.2k
Don't forget panel wipe, as if someone has previously put linseed oil or back to black wax on this will hinder the primer adhesion.
Just need paper to give it a slight key, 1000 grit should do okay.
Edited by derskine
id use a red scotch pad
as above degrease it ALOT , hot soapy water then several wipes with panel wipe and fresh cloths each time
plastic primer it , then a couple of coats of high build primer , sand with 800 wet and on with the top coat
if your colour requires clear coat then straigh on with that , dont sand the base coat
Yes I forgot about panel wipe I have a few ltrs left over ... Thanks
If it were me, I'd use thinners to degrease, and then soapy water and a aggressive scotch. Any couler before the primer.
Try to sand the mottle out of the plastic 1st also, (is there mottle)
Yes it did have mottle but now sanded out and degreased and few coats of plastic primer laid down :smile: shall leave it 24 hours before I sand down..
Awesome put some pics up of the end result
Only if it turns out ok lol..
Well if not, post in here and seek advice ! I love D.I.Y painters.
I have the same bit couler coded, looks much better
Show me your then boss ?
The day i done it :)
looking good boss a clean job you a pro spray man by any chance ?
Yea summit like that i spose lol
Why the hell am I not sending it over to you to do your skills on it :smile:
Cos its better todo things yourself 👍
I'm sures theres many places near you that could do the same job tho!
I know boss am sure I be fine its not like I don't know how to use a spray can lol
Edited by 1vw2many
A few photos its had 3coats of plastic primer , then 3 coats of filler primer then 3 top coats but no clear coat as not sure if it will benefit from it ?
It looks a lot better than the photos..
Edited by 1vw2many
No clear coat? Doesnt it have a non glossy finish?
Well was not sure if it needed it ? is it the done thing ?
Not always, but i no i would.
Give it another degrease, lightly dust a few more coats on, then laquer it.
Ok thanks boss will do :smile:
