Vw polo 63 plate rear wiper judder
Hi my 63 plate vw polo which I've only owned for 3 months has a very annoying fault, when it rains I've got the rear demister on and the heater on full for some reason the wipers judders. I've taken it to the dealership and they've replaced the blade. I get home and it's still juddering I decided to go back to the dealership and this time they allowed me in the garage they asked me to explain the problem. I explained to them and in reply they said don't use the demister when your using your rear wiper blade. What kind of explanation is that ? It's like they made up some crap just for me to leave. I left the dealership with the blades still juddering and even without the demisters and heater on it's still juddering, I don't know what to do now does anyone have knowledge on this or is there any other 6R polo owners who are going through the same problem or fixed the problem.
Any help or advice would be appreciated as this is stressing me out
Kind regards
Adil
  • Views 1.3k
I'm throwing this out there, but it could just be that the blade needs bedding in a little bit, or there is a little too much pressure on it from the spring.
My guess is a combination of both.
run the wiper for a while and do some lifting of the rear wiper to bed them both in a bit :) it is a brand new (near enough) car afterall :)
Hi thanks for the reply could you go into a bit more detail please like lifting etc
Thanks you again and hope to hear from you again
Kind regards
Adil
yeah I just meant lifting up the wiper away from the glass, like you would if you were to change it, just to work the spring that holds it down :)
Edited by R10tz0r
