Polo 6n Open Air Breaking
Flash Red, 3 door 6n Open Air
First stage of breaking, I need to keep it mobile for now so most mechanical stuff not yet available. I'm open to sensible offers on anything if you're collecting and will courier where practical.
Open air roof, fully working, vinyl in good condition with just a couple of tiny 'nicks', one each side of the rear most fold. Inner lining in good condition and free from splits. Completely water tight. To be sold complete with all electrics and switches. Buyer removes, I don't mind if its removed from the roof or if the roof is cut out around it. If needed the surrounding headlining is also included. Dimensions are 127cm long, 80cm wide in case you want to fit it to something other than a polo. £225.
Electric window / electric mirror / central locking upgrade. Ideal upgrade for a base spec, windows work smoothly, mirrors adjust well, central locking not so good as vacuum pump has a leak and needs replacing. Complete with all parts and wiring £125
Seats and door cards for 3 door in good condition but not mint. Drivers as light wear to bolster, passengers has a water stain on the base, the base plastic trims have pulled the screw through on the front seats and there is a cigarette burn on the rear bench base. The good news is the rear bench has head rests and both fronts tilt. £40
Rear parcel shelf, uncut, needs new straps £20
Headlights, electrically adjustable for height, all working. Right hand OEM Hella left hand quality pattern part, both in good condition and free from damage £20 each
Front indicators £3 each
Rear light units £10 each
Tailgate, rust free, paint original but a little faded, with glass £30
Drivers door, rust free, paint original but a little faded, bare £25
Passengers door, rust free, paint original but a little faded, one small pin dent, bare, £25
Bonnet, paint original but a little faded usual stone chips £15
Front bumper, poor paint repair on left hand end hence really needs painting £10
Rear bumper, small scuff otherwise tidy and paint still pretty bright £20
much more available, PM me with what you need.
  • Views 847
How much for the plastic trim that surround the sterio, heater controls etc? its about an inch wide and surrounds those bits, message me please as i wont see if you comment on here :smile:
Roof reduced to £180 if collected or £120 for just the vinyl and frame.
Will split the electric window and mirror parts.
Is the pedal box any good ?
If so, how much posted to Swansea ?
Pedal box seems ok but I would need to check properly and won't be able to do that until next weekend. If its good £25 including courier.
update, following parts sold
Roof and motor
Passengers side door
Passengers side window motor and regulator,
Drivers seat
Rear Seat
Parcel shelf
Central locking pump
Passengers side glove box
Front bumper
Grill
Engine cover
Much more still available, PM me.
