vr6 leathers into a 6N, back seats advice needed
Basically the bench is done and fit already but the back rests I'm having trouble with. I read an article about having to change the metal back plates so the bits that slot in our correct. My issue is that i already have the correct pins but they are at an angle as opposed to just straight. Should i try to straighten them up or just swap my back plates round from my old seats?
  • Views 755
Cant edit as I'm at work but thought i should point out that they're not already bent but the metal around them is just an angle causing the pins to be at the wrong angle.
The golf back plates are about half an inch too long either side, you need to replace the back plates or they won't fit
Yeah swap to the polo plate and it will slot straight in
