MK3 engine parts 3F ABD AAU
Hi since purchasing a new car at the weekend i now have no need for all my old polo spares and so i am stating to get rid of them to make some cash for my new project.
This list will be edited when i find more stuff if you have any requests PM me and I'll see if i have what your after.
All prices are excluding postage. collection from Nottingham NG15 is better but could post at buyers expense.
- AAU engine ECU working perfectly when removed last summer £10
- Complete AAU engine worked fine when removed last summer been sat since £30 Provisionally Sold
- MK3 Starter motor working perfectly when removed last summer £25
- MK3 AAU alternator (i think same as all MK3 alternators) working perfectly when removed last summer £25
- Golf GTI 8v air flow for GT set up to run on my old GT using exhaust gas analyser with no issues also has had spring adjusted to make it more responsive. £30
- ABD engine block with pistons crank, flywheel/clutch, end casings oil pump and rear coolant pipe from water pump. This engine has a knife edge crank that has been honed/balanced with lightened flywheel/ clutch assembly. i have never fitted this engine it was my intention to put it in my GT but alas it never happened. it will need acid bathing to clean up as has been painted poorly by previous owner. £200 Provisionally Sold
- 3f intake manifold taken off my old GT £50
- Two sets of GT/NZ injectors worked fine a few years ago £15 a set.
- MK3 cam belt cover plastic £5
- MK3 GT cylinder head no cam or followers £25 SOLD
pictures available on request but will try and have all pics up by next weekend.
Thanks Rob
Edited by Grubb
  • Replies 20
  • Views 610
Mate do you have gt manifold along with injectors throttle body and ecu? basically I need everything to convert carb to injection.
Gti air flow meter more info please ? pm on way also if above does not buy I would like gt injectors please posted ?
Pmed
I have PM'd you about the air flow mate also i have two sets of GT injectors. i'll put you name down on a set =]
Hi mate i will have to check the TB as it may be an NZ one i have a manifold injectors and a fuel rail witch has broken where it bolts to the manifold but still holds its drink. but no loom and ECU.
If you want to get rid of carb i have a complete injection setup from the AAU engine. As in TB, manifold, ECU, loom sensors and relays also bits like thermostat housing etc let me know pal =] I think they can be used with 1.3 TB's too. Anyone correct me if this is wrong.
Thanks Grubb
Hi, Is the cam belt cover the both halves?
thanks
thanks
No sorry it's just the cover not the piece that sits behind the pulleys or the lower piece that goes around the crank
Interested in the ABD setup and the GT head. Sent a pm.
Have you got the crank pully that drive the alternator on the aav engine I need one asap can PayPal today
PM'd
i do indeed, i can't post till this weekend unfortunately. if your still after one let me know and i'll get it sent out to you.
Isnt the AAU engines single point injection? I'm looking for a 3f setup as they multipoint, correct me if I'm wrong.
Your right pal I just thought you were going for any injection lol. I have in that case a inlet and a set of injectors for 3f and that's it bud sorry.
Nah I'm heading for a mpi setup, how much for inlet with injectors delivered? does that come with throttle body?
thanks
PM'd about the injection parts.
Has the Abd sold mate?
The ABD has gone sorry bud the deposit has been made and is waiting to be collected. =[
Is it the slim starter? Cheers
Not sure what you mean by 'slim stater' it's the early type if that helps ?
