Mk2 Golf AFM upgrade for GT AFM
2 x Mk2 golf AFM used to replace gt afm to allow better and increased airflow will require setting to the car but there is an instruction guide How to do this in the faq section under the engine section
£20 each ask about postage
Also have an adaptor to fit an air filter on the end of one of these afm's and a cone air filter
Adaptor - £10
Cone filter - £10 (has seen better days but still works and did have fitted to my own gt)
Will be adding bits and pieces over the coming days so if you need anything let me know and I might have it
  • Views 208
Is the bolt pattern for the adapter the same as the gt? I'll probably have it, do you have any pics? Whats the filter like? Cheers
the golf afm is bigger so wont fit the gt air box
