Saf's 2014 firesale
Well having a re-think about life priorities and what I want from all the cars, so all of the following is up for sale.
Please feel free to PM to discuss anything
FK Coilovers - stripped back, primed and painted black - £220
KW -60mm Springs - £100
HnR -60mm Rear Springs - £50
Koni Rear Shocks - £60
200mm Rear Drum Conversion (Full) - £80
Sub 60k Jabba R1 ported charger - Rebuilt and run in with 600 miles - £550
Ported R1 charger, needs rebuild, not fully boosting - £250
Mk1 Golf Full Safety Devices Cage including door bars, and top windscreen brace - £600
Several Helix Paddle Clutches - £150 each
Uprated Driveshaft with CV's - £250
2 1/2" SS exhaust modified for Mk1 Golf - £250
PSD Rear SS Silencer - £150
PSD SS Midbox Silencer & Pipe - £100
14x7 Compomotive CX330 Split Rims x 5 with 155/55/14 Nankang tyres - £1000
G40 Parts - Enquire
ECU's
Dizzy's
Boost Piping
Oil pumps, chains, shells, pulleys, bolts etc
Charger mounts
G40 Cam
Full Turnkey - G40 Conversion - 170bhp with RR Print-out. £2000
Rebuilt block - 800 miles ago, new oil pump, new rings, all bottom end shells, seals, gaskets etc.
Block painted red
Schrick 272 Camshaft with vernier pulley.
Ported/flowed head, new valve and guides, gaskets, seals at engine rebuild, painted silver
Thinner metal headgasket,
GT manifold port matched to head,
51mm throttle body,
G60 green injectors,
Jabba induction kit and heatshield,
Boost return mod,
PSD 4 branch exhaust manifold
Helix Paddle Clutch,
Mocal Thermostatic Sandwich Plate with 16 row left front mounted oil cooler,
Stage 4 full blend charger,
65mm PSD Alloy Toothed Belts,
G-lader serviced June 2012, oil seals and apex seals with fresh klubber grease and new gates belt. done 10k
Custom mapped at PSD with all upgrade parts fitted.
ATV Gearbox
Rare alloy Mk2 Engine cover.
Comes with everything to bolt straight into your Mk1-3 polo, will come with custom MK1 golf 5 speed gearbox mount if required.
Can be seen and heard running as currently in my Mk1 Golf.
Full Turnkey - G40 Turbo Conversion. £2000
Rebuilt block - 8000 miles ago, new oil pump, new rings, all bottom end shells, seals, gaskets etc.
Schrick 268 Camshaft.
New valve and guides, gaskets, seals at engine rebuild
Modified throttle body with 6psi boost switch,
K03 Turbo, Stainless Manifold, Stainless Downpipe
ATV Gearbox
Polished Mk4 Rocker Cover
Custom Chip for Spec
HEL performance oil lines, all water lines and alloy water pipe coupler, with take off for water heating.
Aeroquip fitting's on oil drain line, to alloy RPM sump
£25
G40 Fuel Rail complete with fuel pressure reg and injectors x2
Lucas 256mm calipers stripped for rebuild
£15
Rover 218 Turbo Diesel Intercooler
G40 Boost piping (by radiator) & Plastic Clamp
G40 Radiator cover
G40 Charger Inlet pipe
G40 Inlet Manifold x 2
G40 Outer Timing Belt Cover x 2
GT Grill Air Intake – OEM
G60 Charger Inlet pipe
Thin intercooler - poss merc - plastic ends
£10
Mini Radiator (new but knocked about a bit in storage)
Proplus 12" Subwoofer x 2
Volvo Steering Rack NOS - 35700016 - 1206884
Mk2 Coupe S Red Dash Surround
Polo GTI - AVY Oil Cooler without piping
Polo GTI - AVY Oil Cooler with piping
Mk4 Rocker cover with throttle cable cutout
£5
Mk2 Polo glovebox upper cover (covers fuses and bulkhead)
Ford Oil Turbo feed line - 6K67913F
Smiths Oil pressure gauge - Chrome outer ring
Autogauge Boost gauge - smoked
Bosch Recirculation Valve
NOS 180mm Rear Shoes (to fit one side) - Fit Mk1/2/3 polo - Mk1 golf
Mk2/3 Quarter light passenger window (bonded rubber)
Mk1/2/3 standard under car brace
Mk2 Polo Dash Speaker cover
Mk3 Polo Coupe Backbox - standard
Mk3 Polo Heater Controls
Mk1 Golf random water hose
Polo or Golf Washer bottle - 867955457
AFH Oil Breather Pod
AVY Water Housing
AVY Water Housing Inc Thermostat
AVY Rocker Cover Lead tidy
All parts collection from Manchester, lots more to come, please PM with any individual requirements
Edited by grungeisdead
  • Replies 25
  • Views 1.5k
sent you a mail mate
fk coilies prov sold
Also got a VW decat downpipe - 45
Any photos of the G40 rad cover? And any chance you know if it fits a mk2 bro
Not without modification, it screws onto the slam panel
How much modification?
couple of screw holes I reckon, unfortunately both of my mk2 front panels have been hacked about for charger clearance, so I couldn't tell you exactly.
I'm sure GT's came with these too, although the G40 one is bigger as it also has one of the hard plastic boost pipes attached to it.
Will dig out a picture when I'm home, otherwise check out any G40 bay pic :)
be you got a throttle body and if so how much ?
G40 one? only as part of the full setups but will check the shelf.
If I don't I think Birchy does, will enquire
Hoping the Golf SS exhaust has no centre box? pics please? 8>T
It did, it was originally a Magnex system but the centre box was a massive pile of homo-pie and twatted off everything! Ripped it off on my drive one too many times, so welded in a straight through section
Original centre box and added flexi
387401_10151496139106343_1706784203_n.jp
Took out the centre box
Doesn't catch anymore, it's just the wishbones mounts that take it!
The compo's, I have a set of 5, one needs building up, the other 4 are good to go. One of the lips is slightly bent, but will knock out, best done when its split.
Don't have any pics of all the wheels seperately yet, but here are some from the cars
https://scontent-a-lhr.xx.fbcdn.net/hphotos-ash3/t31/p180x540/680343_10151305445611343_1118719249_o.jpg
https://scontent-b-lhr.xx.fbcdn.net/hphotos-frc1/t1/995412_10151736692981343_666614412_n.jpg
https://scontent-a-lhr.xx.fbcdn.net/hphotos-prn2/t1/q71/s720x720/1509840_10152125334461343_1966088011_n.jpg
The supercharged lump on the rollers
http://s274.photobucket.com/albums/jj263/white_polo/rolling%20road%20day%202010%20videos/?action=view&current=IMG_0809.mp4 rr printput http://i134.photobucket.com/albums/q104/winter_snowball/2011-05-15184118.jpg
rebuilt supercharged engine
https://scontent-a-lhr.xx.fbcdn.net/hphotos-prn2/t1/p180x540/9650_10151554733636343_266305859_n.jpg
https://scontent-b-lhr.xx.fbcdn.net/hphotos-ash3/t1/s720x720/64404_10151560723101343_1774456165_n.jpg
https://scontent-a-lhr.xx.fbcdn.net/hphotos-prn1/t1/p180x540/17418_10151560723941343_1804647495_n.jpg
https://fbcdn-sphotos-e-a.akamaihd.net/hphotos-ak-frc1/t31/p180x540/902482_10151585307261343_1750572915_o.jpg
RE: the turbo lump
It's this setup, but with a different turbo (K03 instead of a GT25) sold the Gt25
https://scontent-a-lhr.xx.fbcdn.net/hphotos-ash2/t1/383672_10150474743991343_1963291481_n.jpg
new turbo downpipe and mani
https://fbcdn-sphotos-c-a.akamaihd.net/hphotos-ak-ash2/t31/p180x540/857190_10151496138171343_1383736027_o.jpg
Sold the following to a friend :-
Charger - 250 quid R1 jobbie
Charger Mount
Inlet Manifold
Injector Rail
Throttle Body
Alternator
Starter Motor
CO Pot
Knock Sensor
ECU
Engine Loom
Dizzy
Air filter
Hard boost pipes (Over radiator, and across bay)
Soft boost pipes (from charger to intercooler, hard pipe joiner, hard pipe to throttle body)
G40 Driveshafts £80
68mm Chip & Pulley
Also prov. sold - FK Coilovers.
Will break the supercharged setup, if I get buyers for most things, please post up if interested
Schrick 272 Camshaft with vernier pulley. - £220
GT manifold port matched to head - £70
51mm throttle body - £200
G60 green injectors - £50
Jabba induction kit and heatshield £100
PSD 4 branch exhaust manifold - £350
Helix Paddle Clutch - £150
Mocal Thermostatic Sandwich Plate with 16 row left front mounted oil cooler - £120
Stage 4 full blend charger - £500
65mm PSD Alloy Toothed Belts - £200
Custom mapped at PSD map, 170bhp. - £100
Alternator £80 - NOS VAG, done 4k
Starter Motor £25
CO Pot £25
Knock Sensor £10
ECU £100
Engine Loom £100
Dizzy £50
Well it looks like I have buyers for these
G60 green injectors - £50 (AdzCM)
PSD 4 branch exhaust manifold - £350 (SuperMario)
Helix Paddle Clutch - £150 (AdzCM)
Mocal Thermostatic Sandwich Plate with 16 row left front mounted oil cooler - £120 (1982Mk1)
Stage 4 full blend charger - £500 (BenG40 Gmoney)
SS exhaust (Cav - Mk1 golf forum)
Which leaves me this lot, which I'm happy to keep in the pile (as an easy escape route to supercharged-dom in the future)
I'll drop you all an email over the next day or so. I am away from tomorrow until Monday so I can sort out taking bits off the car in the week / next weekend.
With regard to this to the 62k charger, I dug out some old info and took the charger about for pics
From the previous owner of a breadvan mk2 g40 project he had it for years, I was told the charger was last serviced by Jabba in 2001, dry stored until I purchased it in 2011.
The markings show the last service, and that it is infact a stage 2 charger.
I've since ran it in for 620 miles, taken it off the charger and stuck it back on the shelf since.
There was 62,5000 miles on original engine (which is now owned by dubstar, who had stripped the engine and confirmed it looked like a low-miler Smiley )
Here's the pictures of it, as they tell 1000 words
http://s16.photobucket.com/user/yousafn/library/62k_charger
Still asking the same, £550. It's a low mileage charger which pulls hard.
It was just after the run-in period, that I melted a piston giving it legs in front of an S3.
Took the charger off to inpsect it (hoping it was the charger, not a piston) but upon clean inspection, the charger was shelved and the peril underwent restoration status and got taken off road.
Following bits all paid for :-
1982mk1
Oil Cooler Setup - Mocal
AdzCM
Banded Steels off Golf
Helix Paddle Clutch
G60 Injectors
G40 Crankshaft & Bare Block
Dhayes
Coilovers - FK
Parts that are sold, will be removed this week/weekend and will be in post the next.
Thank you very much all :)
PSD Exhaust & KW Springs - Deposit now recieved
do you still have the mk2 glovebox, and if so can you send me some pictures to cgarfield@live.co.uk just so I can check its the right part
thanks
I've got two mk2 poloes, so its deffo the correct part.
Will dig them out at the weekend and get a photo chap.
cheers, ill look at the condition then as long as its good ill buy it off you. will you be able to post? as I cant get to Manchester very easily. well apart from in march when I'm off to the Victoria club thing, but ill be in no state to collect a part hhahaha
sorry to all those waiting on parts, everything is being stripped this week, and parts will be out before the end of the week.
Many thanks
Saf do you have a mk2 ignition loom?
Are the rear shocks a firm ride and will they fit my polo mk2f I need better ones as I bottom out if I have passengers now I'm loweredd
£10 Proplus 12" sub x 2, i'll take these :)
mk2 polo heater thermo swich (not the switch, heater control thing) give us a call for a better description 07981 261968 (will)
