6n2 rear brakes/ handbrake problems
Hi, when under hard braking the rear drum brakes on my 1.0 make a rubbing/grinding noise. Any ideas? Also the handbrake is really high and can drive off when it.is on.
All help appreciated
  • Views 1k
This sounds very much as if the brake linings have worn down and you are getting metal-to-metal contact between the brake shoes and drums.
Suggest that you get the wheels and drums off as a mater of some urgency and make an inspection of the situation.
Sometimes, noises like this can be attributed to a broken component (spring, ma be) or a foreign body (pebble may be) inside the drum, but this, in itself wouldn't affect the hand brake travel.
Regards.
