mk2f front window screen removal advice ?
I have noticed some rust around the front screen lower area where I think the drain holes are ? anyway am thinking maybe I should remove the front screen ? advice please if I should remove the front screen or not ? as if it starting to rot out, blocked drain holes etc I need to get on top of it before it gets worse..
  • Replies 8
  • Views 847
you'll need the screen out to fix that. best way is to have a few friends sit inside and put thier feet spaced up on the windscreen and gently but firmly push it out whilst you and a friend handle it with care
another option is slash the rubber with a blade if the screen is minto
Well I was thinking I could use the old window seal so do not really want to cut it ..
yeah fair enough then
work your way around from the inside , use a screwdriver to push the rubber over the metal lip all the way around , be prepared that it might crack of theres any nasty chips
plan to have mine out in the summer , got a new ebay seal for it and will get a new screen as mines chipped to hell
No chips on mine, i will wait till better weather maybe summer lol.. how much was new window rubber ? made by febi ?
Edited by mazraclou
£26 ish posted ..no name on it , looks ok quality but who knows till its in , mines perished anyway
Ok might check with heritage see if they can help..
grab a clean used one ...mines perished and i dont ever get to scrap yards , but they're fine to re use if no cracks etc
