Still sidelights?(indicators)
Seen this about a few times lately, how to do make the front/rear indicators stay on with out flashing? For instance when parking and whoring at shows..
Edited by RyDub
  • Views 579
i have seen people put sidelight holders into the indicator housings and connect them to the side lights.
What like drill a hole in it and fit other lights in or?
thatch what i have seen yes, but that is on the front only, i haven seen the back done.
if you were onlt using it offroad then i would imagine you could have a switch that gives power to the left and right indicators, that way they would always be on. but if you wanted them dimmed and bright when used you would either need some sort of resistor pack or a dual filament bulb and holder.
