mk2f rear bumper brackets can you still get them ?
Can you still get mk2f rear bumper clip brackets ?
  • Views 761
If not then a temporary fix is a cable tie under those top plastic rivet things, lock it a bit and hook the lower hooks together. Then use some long nose pliers to pull the cable tie together round the top hook. Works really well.
Sound ok will try it when its time to put it back on :smile:
