Rear light seals?
Hi everyone iv got a Mk 2 coupe and was wondering if it's still possible to get rear light seals new as my boot is filling with water! Is it still possible to get them and where from? Cheers!
  • Views 710
If anywhere has them then it'll be vw themselves so asking an official parts supplier would be worth a try.
You could use some silicon sealent instead. Also the water leak could be something else altogether unless you've confirmed it to be the rear light.
Cheers for the info il give vw a call, I'm pretty sure its the light seals from the path the water has taken, if it isn't il have to keep lookin!
