dent in doors
Hi all, I've got a few small dent in my doors from people opening the doors into mine, what's the best way to get rid of these? Would you just fill them? If so what filler is best? Or try pull them out first, then fill them
Thanks jay
  • Views 805
I've found dentaid were good at getting them out of my 6n's doors. So may be able to get a paintless dent removal, not sure on price per dent because they did mine for free.
If they're only small I would just filler them, not worth the hassle of pulling them.
When I fix dents on a door or something I can't access the rear of I normally screw a self tapping screw into the panel and use a slide hammer to pull it out, and then weld up the hole.
If the paints you are damaged, paintless dent removal would be best.
Ok thanks, they are only small dents so think ill just fill them, I have got a slide hammer just in case tho
