Wiring harness pins
Looking at doing the 9n - 9n/3 tail light conversion, have found the guides on here for rewiring the harnesses so they work properly. Quick question is is it a case of un latching the pins, gently teasing them out with a small tool and just swapping them into the correct holes? Thanks, P
  • Views 603
Yes, the contacts have two securing prongs that need to be depresssed together and then the wire with the contact will pullout of the housing then just put it into the correct new position, Small instument screwdrivers will work or pinch a flat hair pin (not the crickly ones) from your Mrs and it'll do the job :)
Thanks nige, got some jewellers tools that should do the job, just didn't want to rip anything out haha!
Bit if a random one, the fog light switch on a 9n, can I have the front fogs on without anything else/the rear fog on? I don't have fronts in mine but looking at using the connection for a stealth switch for some eye candy haha. Would only want it on off road though, and the front fog connection would seem best bet without cutting the dash to fit switches.
