Mk2f Arch Trim Rivets
Hey,
Going to be removing and refitting my arch trims at some point soon,
Rather than peeling back the arch liners to look, just wondering if anyone knows what kind of rivets are used to hold them on?
Are they just a standard pop rivet (which id have thought may crack the plastic due to clamping force)
Or those other type you can get where the back spreads out like legs?
If they're the second, anyone got any links where to get some?
Cheers.
  • Replies 10
  • Views 950
its a random size so not easily found in the diy stores
its the type that buldges when crimped
ebay or vw dealer
4.8mm pop rivets. They're a standard size. Oem ones are black if you're getting fussy.
dont the oem ones have bigger heads than a standard rivet?
The last set I saw someone buy a bag of from VW didn't.
So they're just standard pop rivets then.
Cheers guys
I have a bag of genuine ones up for grabs if of use.
Could always fire a washer on if the heads are too small.
General size etc isn't an issue, was just confirming the exact type :)
Need a smaller head anyway due to wheel clearance
Part number 906-349-01. Bought some from VW the other day.
