Engine transplant.
Hi I'm after some helpful advice my names tom an I have a 9n3 polo sport 1.4 16v.
I want to put the 1.8 20v turbo engine in my car I can get hold of an engine, gearbox and loom fairly cheap but not sure what else I need. The most common engine is out of a mk 4 golf so will the mounts still be the same as mine ? Do I need the ecu ? Will I need to change my fuel pump ? Can I get/use the traction control system when it's fitted in my car ?
I'd really appreciate some help.
Thanks.
  • Views 516
  • It was available in this model from the factory, so doubt you'd have to go making mounts and cutting your chassis legs. You'll need the whole loom including the ECU I'd have thought!
First Welcome to the forum.
If your serious about doing that sort of transplant, you're looking at a lot of work, fabricating mounts, cutting chassis to fit, major rewiring, Just have a look in the build sections as it has been done on earlier models, but it certainly aint a plug n play job!!!
it does take some impressive work to do, I always find the mid way project shots more intersting than the finished thing
