6n1 changing dashboard lights?
I have a polo 6n1 and I want to change the dashboard lights to blue. I removed the dash from the car but couldn't see what I had to do! The bulbs I bought are blue LEDs.
  • Replies 15
  • Views 5.6k
  • First off Welcome to the forum. The 6N1 had two different types of speedo pod, pre & post Sept 97! the pre had the fuel and water temp at the bottom and the post they were in the top centre, so d
  • What year is your 6n? If you have the older style clocks...like these: Then you simply need to change two bulbs, ( T5 / 509T ) If you have the later style clocks....like these: then you need to so
  • You can do it either way, keep white bulbs and change the coloured filter, or fit coloured bulbs and remove the filter, I went for the second option.
The 6N1 had two different types of speedo pod, pre & post Sept 97! the pre had the fuel and water temp at the bottom and the post they were in the top centre, so depending which you have will totally change the options on changing the backlighting!
I'm also curious about this, since my odometer LED is dead. '96 model.
Please answer for me as well?
Yeah mines before 97! How would I go around changing the colour of the backlighting?
If you have the older style clocks...like these: mDl_mruVhaPvQ9YFi4iHgng.jpg Then you simply need to change two bulbs, ( T5 / 509T )
If you have the later style clocks....like these: m8le36GkSLCJBWjhHZgTBmA.jpg then you need to solder the replacement bulbs onto the board directly, I believe the bulbs you'll need are PLCC-2 SMD's (somebody else may be able to confirm this)
Yours will be illuminated by a strip of bulbs in the top of the speedo pod
Yes! My speedo looks like the first one! Where do I find them bulbs on the unit please?! Lool
Ok so if you pull the speedo unit from the housing, you'll see on the top of the pod the backlighting, if you split the unit and remove the coloured filter, then you can replace it with whatever coloured filter you like
^^ as Nige says.
Here's a pic to help:
I removed the filter on mine all together and fitted coloured SMD bulbs instead.
So it's not bulbs I replace it's a filter? I have blue LEDs so are they useless?
You can do it either way, keep white bulbs and change the coloured filter, or fit coloured bulbs and remove the filter, I went for the second option. :wink:
Sweet thanks mate! I did purchase T5 blue LEDs so they should fit?
Yep, they'll fit.
Some of them are a little loose fitting and will wobble about when you've put them in and won't make a good contact.
I had to bend the two little prongs very slightly to get a tighter fit, just be careful if you need to do this, they're very easy to break!
Okay thanks mate! Lastly, I removed those bulbs, and put it back in without bulbs yet my whole display still lights up green?! Lool all I want is blue dials and dash :P
Those bulbs will only give you the coloured glow on your dials.
The LCD screens will remain green, changing the colour of these is a little more complicated, you'd probably be able to achieve it using polarizing film if you fancied a challenge.
If your dials are still lighting up green after removing the bulbs....then you've removed the wrong bulbs ;)
Cheers thanks
