14 inch wheels on 110mm drop - MK3 Polo
Hey guys,
Looking to buy a set of new wheels that are:
14 Inch
4x100
et 38
6j all round
175/60/14
Reckon these would fit? if not as they are but possibly with lower profile tyres if possible
Rob
  • Views 845
if your on coilovers then just raise it up if it doesnt fit.
Tyre maybe an issue, other than that should be ok.
Method of lowering have you used
hahaha if it aint coilovers - it aint 110mm
What gets you the 110mm drop on coilovers? Is it wound all the way down with the helpers removed?
noooooooooooooooooooooooooooob
60 profile tyres on 14's are donuts, max drop with that size is about 60/70mm
you won't be 110mm drop, there's only a select few who are/have been and you must have coilovers, and then to modify them at that
It's on cut springs and what are the lowest profile tyres I could run?
so its not 110mm then.
Have you had a look at what tyres you can get?
