Polo MK1 Cylinderheads NOS, price lowered
Before reading, sending pm: Please reserve or post that you want to buy head to this thread, easier for me to follow than pm.
Hi,
selling "few" cylinder heads. Heads contains valves + cam as in pictures.
As in title, following heads (part number and how many)available:
052103265CX 3pcs
052103265 X 5pcs (Valve sizes: 28mm/31mm)
052103265AX 5pcs
052103373C 1pcs <- mk2 head.
052103265K 1pcs
Condition:
New old stock
Price:
70£ / Head + postage to UK 51£
or
will trade to chrome pieces or for chrome grille for example.
Finland
Other:
Ask if you need more pics or information.
Sample pics of the heads:
edited: postage price:
max 15kg package to england is 51gbp and to germany 32.8gbp
Edited by polofin
  • Replies 19
  • Views 1.7k
I would like one but non of the part numbers match the numbers on my head. My engine code is HK from a early Mk2 Polo and Golf. Thank you
Edited by Winston
  • 4 months later...
Lowered the price again, with this price. You cant get new valves + camshaft. These are new old stock heads with all new parts.
need mk2f aau 1.05 head
Hi,
these heads wont fit to aau :(.
Br,
Polofin
Any flat ones? The one pictured is for HA HB HH etc but GL GK HK type are more sought after. Oil spay bar with all fittings also useful.
Hi,
unfortunately i don't have flat heads or those bars. :/
Br,
Polofin
cheers any way
  • 1 year later...
And lowered price again, need to get rid off these, 100e in euros, you cant get even new camshaft with this price. Followers in these heads are latest and strongest ones.
Is that 100 Euro delivered. Also, If I wanted to maintain the CR of the engine (ABD) which would I need?
Price is for head, i need to change the postage too since head weights approx 13kg, it is somethin like 30-40 gbp for postage.
If I&#39;ve understood correctly, ABD heads are with hydraulic lifters and thus the chamber in head is different.
That's right yeah, but I intend to put a mechanical head on it. I have a feeling that I'd need a flat one, which I see from above you don't have.
You say you've dropped the price to 100 but the original post has a price of 70 euros
it is in GBP at original post, 1 GBP -> EUR 1.4 hence 70 pounds = 100eur approx. old price was 100 pounds.
But yeah, i think you need the flat one, and i dont have any of those.
Oh, I see. I was being a dunce!
Shame, I could have done with a NOS head.
Do you have any other parts, like performance cams/lifters etc?
Unfortunately i dont have any performance parts available. :/ Only mk1 nos stuff mostly(not many items left since I&#39;ve sold quite many items here).
Hi,
Still for sale? I'm looking for a 1.3 HH head, i'll check the cast nr this evening.
How much for one + shipping to belgium?
Maxime
I have a 052.103.373, i see that one has been sold,
do you have one with the same specs(valve size, porting size, cam)?
also important is the inlet manifold type, I need one like in the picture without the high mountings above cil 2 & 3.
Edited by MaximedeGauquier
Hi, all these heads are with 052.103.373C casting, they've just badged these heads with above parts number on paper markings. The only differences in these heads is camshaft incl. HH.
What I&#39;ve read is that all pre 78 models does have same casting, only internal changed is camshaft. And all heads have 32mm/28mm valves(in/ex). Later ones do have bigger valves.
Ill send you a pm later today, will check the price+postage in euros.
Below is the parst number lists.
2 no longer available; also use:; use if required:; for vehicles with coolant-; heated intake connection; N 016 024 1; N 013 811 5; N 016 153 1; N 013 812 8; HA,HB,HC,HD,; HE,HH,HJ; HA,HB,HC,HH 2 052103351H cylinder head; also use:; use if required:; for vehicles with coolant-; heated intake connection; N 016 024 1; N 013 811 5; N 016 153 1; N 013 812 8; HA,HB,HC,HD,; HE,HH,HJ; HA,HB,HC,HH - 052103265CX cylinder head with valves; and camshaft; see workshop manual; HA,HE - 052103265 X cylinder head with valves; and camshaft; see workshop manual; HB,HC,HD - 052103265BX cylinder head with valves; and camshaft; HJ 1 - no longer available; see workshop manual; HA,HE - no longer available; see workshop manual; HB,HC,HD - 052103351H cylinder head; HJ 1 2 no longer available; for vehicles with exhaust gas; heated intake manifold; also use:; N 013 811 5; N 016 024 1; HA; HB; HH 2 052103351E cylinder head; for vehicles with exhaust gas; heated intake manifold; also use:; N 013 811 5; N 016 024 1; HA; HB; HH - 052103265FX cylinder head with valves; and camshaft; HA - no longer available; HA - 052103265DX cylinder head with valves; and camshaft; HB - 052103265GX cylinder head with valves; and camshaft; FORMEL E:HB - no longer available; FORMEL E:HB - 052103265EX cylinder head with valves; and camshaft; HH
  • 9 months later...
PM ;)
Are any of these still available? Would you be willing to post the United States (I'll pay for it, of course)
