will an engine out of a polo 6n go straight into a 6n2?
i have a 1.6 16v 6n2 gti polo but the engine's waisted - I'm looking at buying a 1.3 polo 6n for the engine and run bike carbs on it.
the engine has been rebuilt with a 1.6 aee head off polo pollished and ported with a 1.3 gt camshaft - 232 degree
will this be a straight swap ?
I have spent the last hour searching for answers and have resorted to asking you guys for help
cheers
  • Views 603
they share the same chassis so it *should* be a straight fit, but you would need the looms for it I think
nice one.thanks
If your running bike carbs is will be a lot easier than a normal engine swap, you wont need the Ecu or loom if your running the mk2 dizzy and loom, id say its most likely does fit as the 6n2 also come with the 1.4 mpi engine from 6n so I guess it will
You will need to think about gearbox change.
thats cool got a gearbox with the 1.3 gt engine
anyone hazard a guess to what sort of power i could expect with the bike carbs?
I prefer the older engines as i think they are stronger and take more punishment but dont want to be loosing too much power!
thanks again for help
