Polo 6n 1.4 16v keep or sell
Had my valver for just over a year now and I'm still impressed with how well it drives but not sure whether to keep it or sell it. Its bog standard with just over 64,000mls and almost original apart from 6n2 gearknob & gaiter. Its had a new clutch and gearbox bearings and fluids flushed and replaced. The cambelt has been replaced and all the front end bushes replaced. I've replaced the thermostat and temp sensor. Its fairly tidy but the pic hides rust on both doors and a little around the rear arches. Thats about it negative wise but to bring it up to how I want it I want to swap the steering wheel for a momo team upgrade the standard speakers and maybe add a small sub. Then it needs lowering and I fancy some solitudes but thats about it as I like the oem look with subtle improvements. But that lot could cost 5, 6 or £700 so it got me wondering whether I should flog it and move over to a newer 6n2 16v ?
What would you do ?
  • Views 686
If it was me I'd keep the 6n.
I prefer the look of them to a 6n2.
Also sounds like you've had a lot of work done to the 6n, would be a shame to sell it, buy another car and find you need to do all the work to that car too.
I'd just keep the 6n and spend the money modding it to how you want it. Best time to do it is now since you seem to have all the essential mechanicals sorted.
Must admit I definitely prefer the dash in my 6n to the 6n2 and as the guy at the garage said today as I was having the tracking done "dont see many of these". I imagine you get that a lt in a G40 though :smile:
Its true though I do have a pretty solid base to build the car I want.
If you get a 6n2 then you would want to put different wheels etc on that. Your 16v looks nice and you have done a lot to it. Sometimes its better the devil you know.
Very true :smile:
I wonder what it will cost to get the bodywork sorted
My 6n is tidy but has rust on rear arches and on both doors, not major but enough to be a problem, all I have done is rub down and hamerite it. Cheap and it will keep it at bay for a while.
Cheers buddy I will probably do the same.
