Engine Noise Just Above 1000RPM
Hi All,
Hopefully someone can help me. I have started to hear a blowing/beefy noise from my engine when its just over 1000RPM. The noise sounds like a hole in the exhaust. The engine sounds fine at idle, and also when past around 1174RPM. I have scanned the car with VAG-COM and have no error codes. i have used VAG-SCOPE and have found the the noise to occur from about 1030RPM to 1174RPM. Anything above or below that and the engine sounds absolutely fine.
The have checked the engine bay and can't see any problems or anything rattling around. The noise seems to be coming from around glow plug area but i may be wrong. The engine is the 1.4 TDI 3 cylinder. I'm seeing no other problems at all. Only the noise from the engine
Thanks in advance
Oliver
As you mention the exhaust, is it possible that there is a heatshield (the flimsy looking aluminium ones) loose ? they can resonate at certain RPM.
I once experienced a non-genuine air filter element that did the same thing.
Regards.
