Bumper strip removal---how to?
Hi guys I have a vw polo 6n 2000 1.4s 16V. It is in silver and has silver bumper strips, is there a detailed guide on how to do it anywhere?? Thanks a lot.
Louis
  • Views 2k
Are you sure it's a 6n and not a 6n2?
Going from what it says under your username you have a 6n2
If it is actually a late 6n then get them warm and they'll pull off, they're just glued on.
Another method is to get some thin string/fishing wire and work it behind the bump strip and 'cut' the glue.
You've then got the fun job of removing the glue left behind, I hear a toffee wheel attachment for a drill is a godsend for this.
I'm not sure if this is the same on a 6n2, ...I'm pretty sure there are holes underneath on these that would need filling.
Edited by BoWzER
Bowzer thanks a lot man, just been through your whole thread with your blue polo, turned out amazing! New to this forum as only just got a polo really but thanks for your advice I need to get myself a heat gun as they seem to be needed quite a lot!
